Nah, Planet, i'm in NSW. I have never seen the car.
But, if i was in QLD i certainly would have either snapped the car up or at very least had it thouroughly inspected.
Seems like a very good price for the extras it has.
Free bump for you Greygirl as i'm also getting married in a few weeks and just went through the process of seeling a car so i know how you are feeling.
Good luck.
Can't understand why it is still available.
  • Replies 99
the car is still avaliable because we have had every time waster under the sun interested in the car. they just dont have the money.
to see pics of the car go to the first page on this topic and see a link that simon( i think thats how you say it) and the pics are in there. still having trouble sending pics dam comp
interested also, im in vic, and dont mind flying up.
i had a 32 imported but the guy is finding it hard to get it on the road, cause of the seva law.
can you send your details and pics to my email please.
[email protected]
cheers.
the car is a 1992 yes we want to sell ugrent but not stuiped or dumb to sell for $10000 sorry. we know that there is no other R32 with these mods for sale at this price in australia so no i am not stuiped to sel the car that cheap $13000 is cheap take it or leave it i dont care either way
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
