  • Replies 96
awww dang will apply for one later. but ill pop down for a looksy
Call them, you may be able to get one on the day. That's how i got my first one years ago, at a PIARC day.
You in for both days Matt???
ahh kool ill give em a cal. whats the cost like?
Actually, one other question...
Does anyone know where I might be able to get a couple of 25L tanks to bring fuel down? I don't want to have to do a day trip to get fuel!
pretty sure if you go to like a 4wd accessories shop that sell stuff for of roading they should have big jerry cans that big.
Thanks - I've been told that supercheap sell that sort of stuff :thumbsup:
G'day Budge - Thanks for the offer - I'll see what supercheap have - but if there's nothing available, I'll take you up on that offer...
I'll PM you later if I don't have any luck.
Cheers,
matt
Mat, I have 2 you can borrow if you like.
Pick up and drop off in Rowville.
If anyone else needs Jerry cans i have two 20ltr cans myself and i will also be going to PI for the weekend.
Just call me on 0427 076490, if anyone wants to use them for the weekend.
NO SMS'ing as i can't reply on my work phone.
Cans have previously been filled with BP Ultimate; just in case it matters
Matt - I'm just there for Saturday... can't make it Sunday.
As for fuel cans you can get 20ltr cans anywhere, supercheap, bunnings etc.... But there is BP Ultimate in Cowes not far from the track. I take that 100ron optimax stuff with me so i use jerry cans.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
