  • Replies 96
awww dang will apply for one later. but ill pop down for a looksy
Call them, you may be able to get one on the day. That's how i got my first one years ago, at a PIARC day.
You in for both days Matt???
ahh kool ill give em a cal. whats the cost like?
Actually, one other question...
Does anyone know where I might be able to get a couple of 25L tanks to bring fuel down? I don't want to have to do a day trip to get fuel!
pretty sure if you go to like a 4wd accessories shop that sell stuff for of roading they should have big jerry cans that big.
Thanks - I've been told that supercheap sell that sort of stuff :thumbsup:
G'day Budge - Thanks for the offer - I'll see what supercheap have - but if there's nothing available, I'll take you up on that offer...
I'll PM you later if I don't have any luck.
Cheers,
matt
Mat, I have 2 you can borrow if you like.
Pick up and drop off in Rowville.
If anyone else needs Jerry cans i have two 20ltr cans myself and i will also be going to PI for the weekend.
Just call me on 0427 076490, if anyone wants to use them for the weekend.
NO SMS'ing as i can't reply on my work phone.
Cans have previously been filled with BP Ultimate; just in case it matters
Matt - I'm just there for Saturday... can't make it Sunday.
As for fuel cans you can get 20ltr cans anywhere, supercheap, bunnings etc.... But there is BP Ultimate in Cowes not far from the track. I take that 100ron optimax stuff with me so i use jerry cans.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
