  • Replies 705
Posted Images
Dirt, can you provide some more details on the parts used and the installation detail? Would you be keen to produce a kit for me/SAU members?
id be super keen for a kit too paul!
i reckon theyd sell just as good as ur 2wd switches :)
hi gents
hey paul ! good idea as gave as a bit of a scare !! will look at that (your setup)this week also will be fitting an idler pulley to stop belt flap.
as far as letting as japanese driver drive our car, no as this point that wont be happening, maybe in the future but this trip is to see how we stack in performance and driving.
a few pics of car at test day yesterday, video incar to come.
i just can't believe how well the car ran yesterday and the speeds managed! brakes are again being tested beyond their limit!
cheers russ
the only thing is how do you start the car? when it's off there is 0 pressure. actually I guess you just have to wait for it to build a bit of pressure on the starter then the switch will deactivate. I would like to see a kit set to cut ign and fuel at say 1bar and just have a rocker switch in cabin (preferably sprung so you have to hold it down) that you hit to enable starting.
also, it looks like I may be able to get a bit of time off early december and may crash this party in tsukuba. I'd love to see you guys turn a few laps and share a few beers after too. nismo festival the week before would be nice too as that's one thing I haven't done in japan.
MATE You are so very welcome to come along! it will be a blast
last count ithink there are 16 of us! let me know this week if you want to tag or whether you will do your own thing.
would be great to to meet you and have a few!
cheers russ
cheers russ
dont forget to drop me a line too, when you get here Russ, im keen as mustard to get out and see you and the rest of the action , heck maybe even meet the legendary baron, even show you guys where its at for topping up in tokyo.
looking forward to december...
Adam.
2630 yeah needed to put some decals on the car to thanks those sponsors that are helping us out! but i love the all black look myself!
hey john, that was mark not me! havent even drivin the bloody thing yet! :)
russ
thanks 2630,
here's another
russ
awesome. the bit where you came across the fishtailing BMW 2002 was interesting but a little hairy! The car sounds great and is being driven well. I imagine you will have to have a look at gear ratios for tsukuba. It seems to me that it was well set up for QIR but wont you make the gearing a little longer, especially in 3rd and 4th for the japanese trip?
Russ, i am also wondering why youre using the standard GTR S-wheel???
surely its time to get a different tiller?
Adam
hey john, that was mark not me! havent even drivin the bloody thing yet! :D
russ
Yeah as much as said i dont like them you have to thank ur sponsors if u are lucky enough to have them, again : :) Also love the rego plates :(
Edited by 2630GTS
i think the vid is making the gear ratios look quite short, but that is not the case.
mark is changing from third to fourth at about the 170 kph point and from fourth to fifth at about 230 kph , it was hitting to 275 odd on the back straight of the national circuit and 245 on the front straight in that video. with rpm currently top speed i think is about 285 kph.
cheers russ
I use a toggle switch to override the relay circuit (you must use the toggle switch to start the car as a motor thats not running does not have oil pressure :) ). We use a 20psi hobbs switch. Once again Richard you are on the money.
DiRTgarage can produce a kit form of this system with all parts and full installation instructions if there is enough interest.
They will be made with the same high quality of the 2WD/4WD switch looms we already produce.
What do you guys think ? (there is some obvious interest)
Russ...sorry to whore your thread...but you guys can have one free of charge...hell ill even install it...it will only cost you guys a return plane ticket to come over and see you guys compete. :D
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
