the new fuel system for the r33, extra sx fuel pump was required , as one would have been pas the limit!! getting there should be on the dyno soon ! couple of weeks.
dry sump resevoir still to go in back there this weekend with its oil lines.
Edited by giant
  • Replies 705
Posted Images
good to see its nothing over the top.
but, is that a standard battery?
haha no , it's just a sticker, its a special standard battery!!
the car has been sitting for so long i'm not sticking anything else in it until it's up and running again. it's been nearly two years i think!! :D
Sounds like my kind of place!
lol thats cool
Didnt you have a 5 series though?
Never had a 5 series... I'm not *that* old yet :blink:
Don't worry, the silly beemer will be left at home. I got something else to come out and play with :D
the r33 was going to be circuit only but have never had time to finish it off! so trying to finish it now and get it on the track and sell it. it will be a good car it has had alot of money spenton it and hardly turned a wheel it was 80 percent built before we got it.
yeah too many gtr's want to get back to just two!! one each (not that you can ever have too many but the wife does get cranky) :D
the engine bay as it stands tonight, still a bit to go,, trying to make room up the front for the dry sump pump, which means repositioning the thermo fans and a few other bits and pieces.
What do you use the R33 for Russ?
Or what do you intend to build it up for?
Seems you have a GTR for every situation. "Collect the whole set' eh?
didnt you have an evo? have ya still got it?
1. I don't have a mullet.
2. You're thinking too hard. It's a little more obvious than that... We're on SAU after-all :D
Total = 5.8L TT
M3 = 3.2L
Difference = ?
hehe! it will be good to see either way!
It's nothing special, just an R32 track bitch that I'll have fun with and spend way too much money on :blink:
Congrats on your results in Tsukuba btw... Definitely did Australia proud :D
Can't wait to see your beast in the flesh... Those YouTube videos are like teaser porn. All the action, but no money shot :cool:
2. You're thinking too hard. It's a little more obvious than that... We're on SAU after-all :blink:
Total = 5.8L TT
M3 = 3.2L
Difference = ?
Yeah i know it would be obvious
Have you got pics of it? :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
