Damn str8!
..so tight, if stuck a lump of coal up there, in 2 weeks it would be a diamond.
Now, where are those scans?
that friggin tight i cant even fart sorry guys no skanna u gunna have to do wot i did and b b b b buy it.or cum ova and ill let u look for a buk
https://www.sau.com.au/forums/topic/187190-congrats/#findComment-3384923
Yep, good job to Brendan for winning the best Stagea award on the day! It was very well deserved, even though ALL of the Stageas there were well presented (except mine, I was so busy leading up to the event and helping out on the day that I didn't get time to detail or even wash my car!)
More information is here, and the article was very well written by one of our own here at SAU - Andrew "nuttsHunglow" Hearne. Quite a number of the photos were taken by SAU people as well.
https://www.sau.com.au/forums/topic/187190-congrats/#findComment-3386352
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
