There is one circuit racing r34 gtr it used to run nations cup, that and the ex-white and the beale n1s are the only ones I know.
there are a few quick street/track ones as well
ex-Whites R34 is now owned by Dean Grant. It was at Dutton Vic this year and I believe still does a few of the Targa rounds. Beable still has his R34 N1 as well.
Mark and Russ (gaint) are building a time attack one as well. Otherwise most are like mine in that they are still street registered but mainly used for club racing / touring rallies.
Dean Grant R34 N1
My GT-R
There's this really DEDICATED R34 GTT in Melbourne. Black R34 with a huge ass wing and stickers. Big turbo, rear seats removed and 1/2 cage. :D.
And he is on the forums :)
When he rips the dash out we'll call it a dedicated track car! :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
