Hmm interesting, the shit a coil pack tonight with only 20,000km's seems a bit odd, could just be a coincidence, cant find any info on forums were it seems to be a common problem. Has anyone heard of this hapening? Hope nissan AU stock them, otherwise it might be easier to get some out of the states...
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/
Just cruising in 4th at ~60k's and it dropped a cylinder and turned into wrx... pulled over straight away, gave a quick check of all the vaccume lines disconnected the battery and reset the ECU, started it up and it went fine for about 5 mins, got just around the corner from the workshop and same thing again...
Narrowed the coil pack down and moved it to the opposite bank and the problem went with it so i knew it was the coil pack... 200 dollars ex melbourne from nissan should be here tomorrow, bit of mission though. wouldnt think a car with a "claimed" 20k on it should do that...
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/#findComment-3386735
No they were just standards and couldnt track down ne aftermarket ones quickly (if they exist) without going to a MSD DIS ignition system like what i have on the race car and dont have the money for that right now...
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/#findComment-3388622
Problem was fixed for 20mins, got rounf the corner from my house and same thing again.... Pulled codes out of it 3510 - Cant find anything for that one... 1103 - Map Sensor Heater (not ignition related...) and 1130 - Swirl Control Valve Control Solenoid Valve (whatever that is, but im fairly certain its also not ignition related), a little worried the ecu may for some reason shitting itself... not real happy atm...
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/#findComment-3389947
It was a week out of warranty :thumbsup:
Took it too nissan and there scanner could talk to it...
Put the 3rd coil back in today after checking the power and eart and trigger wires to the coil, added an extra earth just to be on the safe side... And it was running super fuely, Tested AFM voltages and one was a bit sus... After i put the pop charger on, when ever it rained heavy the car would actually ingest a little water... im thinking this may have lead to the AFM mis reading... fueling the car up, foulding a plug and finally melting a coil back due to the extra resitance... and thus killing the second one...
Now with a new set of plugs and new coil the car has a miss that seems to be moving around.... and is very very fuely...
3 coils, a set of plugs and a new afm... this is turning out to be a fairly expensive adventure...
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/#findComment-3397687
Yeah pretty much, I dont know if it had nething to do with the aftermarket front bar, or not but the pod filter definately wont be going back on....
Yeah im pretty sure its the same plug, if this afm doesnt sort it out tomorrow would you be keen to try it out for a carton or similar?
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/#findComment-3397721
Ok what a mission!! But it seems to be fixed for now...
Finally replaced the AFM after nissan ordered the wrong one... Started the car, still missing... Took it for a drive to try clear it out and no change... Took all the plugs out only to find that one of the brand new ones that were supplied had the gap completely closed up... (i was frustrated when i put them in, usually i would check that sort of thing..) replaced that plug cleaned all the others as the car was running mega rich. And went and cained the ringhole out of it to see if anything would fail again... So far it held up to that and the drive home.
So hopefully all is well...
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/#findComment-3400568
Well were now onto coil pack number 4 after today.. same one... no. 2 coil pack melted with side all blistered out.... I think nissan jynxed it by accidentally sending me an extra 2 coil packs today... I have now completely re wired the ignition loom...
If it dies again it can only be computer related... which could turn into a bit of a nightmare... fingers crossed its stays good... who knows... the last one survived a skid pan and about a 1000km's... go figure..
https://www.sau.com.au/forums/topic/187670-dead-coil-pack/#findComment-3415486
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
