  • Replies 112
I don't know if I phrased my post correctly.
I was trying to say that if a RB25DET is capable of 270-300rwkw on standard internals, then a RB25DET NEO that has GTR internals would be able to handle even more power on stock internals.
since when can u put rb26 parts into an rb25??? :D i thought nothing was interchangeable
since when can u put rb26 parts into an rb25??? :w00t: i thought nothing was interchangeable
I probably shouldn't of said gtr internals because that wouldn't be true. I retract that comment.
RB25 NEO has solid lifters & GTR rods (note: not pistons) thus making it a stronger motor.
If anyone has more info on the internals of an RB25 NEO, please add to this.
Correct.
Now a RB25 is safe for around 270rwkw and 300rwkw is starting to push things a little bit and everyone one knows after a while she will go bang. Now with the RB25 Neo, that has some slight different internals, would we say 350rwkw is safe??
Correct me if im wrong, but regardless of GTR rods, i still think 350 at the wheels is going to break something soon on a RB25 Neo.
PS: Still can't believe this thread isn't locked :D
Here we go. Bunch off Mr know it all. Plz. If your a mechanic. Put your 2 cents in. If your not then Plz. Plz all mighty Shut the f**k up. Eg. Ardie. Lets give him a hand for knowing it all. Too bad mate you don't get your little hand dirty bc we all know your a lil shit behind a computer. And we know you don't like getting dirt under your finger nails. We call Guys(kids) like yourself a milky way boy. Or softy. What ever you want to call it.
Seriously, you are pathetic little kid. Cut the f**ken crap..
Just bc you own a skyline dosn't make you a mechanic you dumb shit.
Ardie plz, drop the issue or else. If you keep this up, bad things would come to you.
Requesting a lock down Thank you
Edited by EVLR-34
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
