Hey people,
im selling my Xbox 360 Premium Consule its got the 20gb hard drive, its got the firmware upgrade which lets you play backed up copys,
it comes with 2 original games, 7x backed up games, 2x wireless controllers, custom face plate and custom carry case.
Saints Row (orignal game)
Crackdown (orignal game)
Gears Of War
Lost Planet
Bioshock
Call of Duty 3
Burnout 3
Fifa Soccer 07
Top Spin 2
Can Arrange an extra 7 games, buyers choice of which games for no extra cost
Im asking for $600 ONO plus postage and handeling
Additional Information about Microsoft Xbox 360™ Premium Console
Key FeaturesConsole TypeHome ConsolePlatformXbox 360Gaming TypeOnline Gaming
ProcessorProcessor typeTriple Core IBM PowerPCProcessor Speed3.2 GHz
MemoryInstalled RAM512 MBInstalled Cache Memory1 MBMemory Bus Bandwidth256 GB/secRAM Speed700 MHzRAM technologyGDDR3
DisplayMax. Resolution1080 x 720
GraphicsGraphic ProcessorCustom ATI Graphics ProcessorGraphic Processor Speed500 MHzGraphic Card Memory10 MBFill Rate1 Million TFLOPSPolygons Per Second500 Million
Storage TypeHard Drive Size20 GBOptical Drive TypeDVD-ROMOptical Drive Speed12x (DVD)
AudioAudio SupportDolby Digital 5.1, StereoAudio Out6 Channels, Digital Out (Optical) Connector, Line Out, Multi-channel surround sound output, Proprietary Audio Out, SPDIF out
Technical FeaturesCommunication TypeFast Ethernet, Gigabit Ethernet, IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, Infrared, Proprietary, USB 2.0Controller Pad Ports3Expansion SlotsMemory Card Slot x 2Main Controls4 Way Cross Keypad, A/B/X/Y Buttons, Directional Pad, L/R Buttons, Start/Select Buttons, Thumb StickWireless CapabilitiesInfraredInput / Output Ports1 x Game Controller Port, 3 x USBDVD Movie PlaybackDVD Movie Playback
Other FeaturesHDTV CompatibilityHDTV Game supportOther FeaturesProgressive Scan DVD Playback, Voice ChattingParental ControlParental Control on DVD with ESRB Rating, With Parental Control
DimensionsHeight7.6 cmWidth30.5 cmWeight3.49 kgDepth25.4 cm
MiscellaneousExternal ColorWhiteSupplied Accessories1 x Game Pad, AC Adapter, AC Power Cord, AV Cable, Battery Pack, HeadphonesRelease DateDecember, 2005
Edited by maco_boy
https://www.sau.com.au/forums/topic/187895-xbox-360-premium-console/
forgot to add its also got the cooling mod upgrade so it will never overheat or get the 3 red rings valid at $115 and it comes with a life time warrenty
Edited by maco_boy
So the whole Xbox 360 has a life-time warranty, or just the cooling fan?
+ when did you buy this system? (how old is it?)
Edited by HotPlates
yeh sorry ment that the cooling system has a life time warrenty, so the xbox will never overheat or get the 3 red rings,
i've only had it for 3 months
selling it cause i dont play it anymore and saving up to get a skyline :laugh:
As far as I'm aware all modded Xbox's are banned from Xbox live. The online systems communicate with the machine to see if the firmware's modified or something. All new games are brought out with hidden patches on them too that detects if the system is modded.. so any "new" modified firmware that gets onto Xbox live will eventually not work.
" never say never mate with the 3 red light problem "
i have one of these console tho and its great :down:
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
