OK ENUFF PPL SO THIS FRIDAY AT 7:30 MEET AT UNKNOWN (PM ME FOR LOCATION
NEVER ORGANISED A CRUZ B4 SO IT WILL BE MY FIRST ONE (CUT ME SUM SLACK lol)
I WONT HAVE SHEETS BUT EACH LOCATION WILL BE MADE UP AS WE GO
NO STUPID BEHAVIOUR COZ MOST OF OUR CARS ARE DEFECTABLE AND WE DONT WANT BACON FOR DINNER :)
I WILL BE IN THE WHITE 32 WITH GTR FRONT N I WILL BE THERE A BIT EARLIER
SO PLEASE COME OUT, HAVE SUM FUN, SHOULD BE AN AWESOME NITE
Edited by SLY-dN
  • Replies 136
Posted Images
sweeeeeeeeeeeeeeeeeeeet im in so need of a cruise where and i finish work at 5:30pm friday and dont normaly get out of there untill 6pm so we could all meet at my work or somewhere else close
i was thinkin of meetin at bunnings Mile End across from etsa park at like bout 8pm but depends on amount of ppl that are interested,
prob do hills n suburbs
i would but ive got gazzanats this weekend, so gotta keep the girl all clean and all and give her 3-4 coats of wax too..................man my elbows are gonna kill me after that LOL
if more people will go me and my friend in her skyline will rock up..
i may need a lift if your willing from memory your up my way, thats if my car isn't back on the road by friday
:sorcerer: i recon we should just have one anyway no matter how many ppl rock up cause you always pick up ppl along the way :)
so true about picking up lines on the way
you can see the 'great adelaide' skyline from Mt Lofty :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
