DW man people will PM you its late some have gone to bed some @ work and some like me if bringing my car may get the details of someone else :yes:
but may possibly still get a lift as being passenger has its good points too means i can take the TZ3 out for a run :) ... btw thats my camera
  • Replies 136
Posted Images
i need the hub which is attatched to the far left but i now belive i undo all the bolts on the far right that is closest to the diff center that drops to the ground and i smash that with a sledge to get it off the hubs
<br /><a href="http://maddox.xmission.com/hatemail.cgi?p=1#CAPSLOCK" target="_blank"><img src="http://maddox.xmission.com/keyboard4.jpg" border="0" class="linked-image" /></a><br /><br />
<br /><br /><br />
lol thats gold man
got the PM cheers for that :w00t:
and If anyone is looking for a goodtime out next weekend Im playing @ the Producers Bar (check my sig) and will have plenty of flyers with me if anyone wants some. >>>>insert shameless advertising pun here<<<
I will be the one in the DR30
a mate of mine has a TT SS ute (might have seen it at G1 out at lala land) that made 437rwkw on 8psi (injectors at full duty, and a rly safe tune). he has had the fuel system sorted, and now it makes some bullsh*t power figures (not sure what atm), can now wind up the boost up tho
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
