It's the second last track day this year at Symmons.
$85 entry.
Should be a great day, Plenty of action and heaps of runs.
Everything from Porsche's to SR20 Powered Preludes to 59second GTR's to STI's and EVO's.
For more information visit http://www.nwcctas.org.au/ or PM me.
I challenge anybody to run a 1:05.73 or better in a RWD Skyline.
https://www.sau.com.au/forums/topic/188354-nwcc-track-day-281007/
clutch finally died, and the diff is stuffed. so i've got the car on the hoist and dropping the engine out. And i'll get a tomei baffle kit for the sump and install it while it's out. And i'm gunna get ajustible upper arms at the same time, otherwise i'll just distroy my tyres.
Looks liek you got a fair bit of work ahead of you then. i loccked my rear diff on saturday. Just gotta get my car ready this week befause i go to Hong Kong and Vietnaim for a couple of weeks and get back the day before the track day.
Has anyone seen the red R32 gtst with GTR gaurds, bonnet and 25 that runs around the track lately? Last i saw of it was just after it was tuned, made 330ish i think but that was well over a year ago. Think it used to do 63's but would expect it to go alot quicker now. Everyone will see Brett O'shea's VH commodore back out there soon, wants to get under the minute mark. Did 61's aspirated with 315rwkw, just fitted a blower so that should be interesting.
the red R32 killed it's gearbox in the first race of the first round of the TSS at Baskerville Feb this year. It's waiting the arrival of a six speed sequential gearbox from Hollinger. will be back competing in the TSS for 08.
Oh ok. Think from memory it ran a VL turbo box, didnt think it would hold up for ever. Yeah it had a few stickers on it. When i worked at Pride Autos it was down at Driveshaft City for ages getting the engine rebuilt, with all these goodies it should easily see 60's. I wonder if Cooper will have the torana out there, still havent seen it on the track yet but apparerently its doing mid 60's aswell. Everything seems to be getting quicker....
I think you are talking about Bill Fultons 32. He is already doing 60 at Basky
Yeah think he made that number on elf though, either way it would still be a fun car. Whats the plan for your diff? Spending the dollars or doing the cheap fix? Did you end up getting a bigger master cylinder to overcome the long pedal after travis fitted the big brakes?
i am yet to see it but am keen to. a mate of mine made the carbon fiber door skins for it.
looks like the TSS will be pretty huge next year. i know at least one person that will more than likely run in all of them next year. one other that has a car almost complete but that may not get there till half way through the season and if gesty runs they will have to make a skyline class of its own. haha.
i thought he was a rep for dunlop as most guys on here get there tyres of him.
I've got a Nismo clutch pack kit for it, put's better & extra clutches in, and people that have used it said it's pretty close to a nismo pro diff but better to drive.
I havn't got round to fixing the master cylinder, i've just got used to touching the brake with the left foot at the end of the straights. I do need to replace my pads though :)
  • 3 weeks later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
