  • 3 weeks later...
  • Replies 67
hi everyone, i have found a set of wheels for my r32 gtr so these are up for sale, have to get rid of them, for $1800, had buyers for them but they had trouble for delievery to their state, they are currently on my gtr so $1800 is what im after becoz i need to put another $1000 on top for the wheels that i want, any buyers and no stupid offers, these wheels have been price dropped big time
Edited by tony_nivin
come on guys, got some other after market parts for r32 gtr,
r32 gtr n1 bonnet lip, it is fibreglass and its still in gel coat, never been used, $70 posted in australia
the tough genuine hpi exhaust manifolds at $650, these are worth big money, go to the hpi site and see for yourself
got some other standard gtr parts for sale
come on guys sum1 must want these wheels at this price for their GTR godzilla
these are still for sale, surely someone needs this stuff for there GTR, especially the manifolds and the n1 bonnet lip at this price, com on guys!!!!!!
ive got a brand new fibreglass n1 bonnet lip for sale, never been used, still in gel coat for $55 plus postage
water pump in good condition due to upgrading to an n1 pump $25
standard r32 gtr cam gears $40+postage
standard r32 gtr cam gear cover $35+postage
standard r32 gtr timing belt in brand new condition $15+postage
front springs to fit a r33 gtst, i dont know what kind they are but came off my cuzns car, take dem $35+postage
genuine HPI exhaust manifolds, stainless steel, no cheep stainless shit, this is the real thing, worth good money $630ono plus postage
also the wheels, there still up for sale, got heaps of people interested in them but not replying to my emails
  • 1 month later...
bumpppp.... oppen to serious offers and also open to trades for something that will fit gtr and also will throw in some cash on top for the right wheels and must be in 18 inch and also wanting 18+9s or 18+9.5s all around,
cheers guys
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
