head light is all fixed, big thanks to Ricky (SKY GTT) done it on the last cruise. we found out the globe was around the wrong way or sumthing like that.
r34 turbo and non turbo suspension is different. turbo has fork shape ends in the rear, non turbo has eye shape. i know r33 fits in the rear but need 2 make sure it fits in the front as you cant buy HKS, Cusco etc coilovers in mis matching sets.
cheers luke
Edit: what suburb u in Steve?
Edited by Luke_ENR34
are you buying brand new coils if so i highly recommend seeing Ryan @ ISC performance he can get the end swapped over to the coilover is R34 but the end its eyelet
i had the same problems becuase i bought GTR coilovers
you can still come up and we can try them out you can even come for a belt in my car to see how the ISC hold the road
EDIT im up tee tree gully
ive heard good stuff about ISC coilovers, but just a sucker for jap stuff. no offense Ryan :worship:
would still like 2 see how they handle on the road.
will let u know when im free.
ordering wheels soon so need some coilovers to make it look good.
i found that engine upgrade you've so desperately wanted :worship:
http://www.trademe.co.nz/Browse/Listing.as...2051&v=List
so what do you want to do about coils you wanna see if my standards fit you
ring ryan ask where ISC are made
fu*k thats hot.
i wanna make my car all ready for scs next yr.
hoping for 450kw at the wheels.
just to see if standard r33 fronts fit in a r34 front.
hehe, post count from the old thread of 300 pages:
Who posted in: SA Wasteland?
Poster Posts
Sambo33 1066
Nozila 1040
Deluxe 371
Madaz 296
Sinful 292
Pauly33GTS-t 202
Cubes 161
pokie 154
Nightcrawler 107
heslo 105
Sl!m 95
Steve 87
KISIN 83
Whiplash 81
sinistagtst 81
Hotwire 76
Sambo & Nozilla... holy crap!!
"I have 3 words for all of ya'll... Get A Life!"
I didnt work it out dan. When in the SA section, click on the post # for each thread (ie. ~6000 posts for old wasteland) and a window pops up showing you all the posts. Found this out when I accidently clicked the number instead of the title :dry:
I didnt work it out dan. When in the SA section, click on the post # for each thread (ie. ~6000 posts for old wasteland) and a window pops up showing you all the posts. Found this out when I accidently clicked the number instead of the title :nyaanyaa:
Suuureeee.
:thumbsup:
ive heard good stuff about ISC coilovers, but just a sucker for jap stuff. no offense Ryan :nyaanyaa:
Hey Luke,
Hope you have at least $15000 to put into your engine to make that sort of power reliably i was thinking more like $30000 for all the stuff you will need.
Good luck with it though. :thumbsup:
Hey Luke,
hahaha we all goto have dreams ... would be a stinka of a car if you did do that
wanting to ask someone a favour with a 33, didnt wanna waste starting a new thread for this but wondering if someone could measure their dash for me, drivers to passenger so end to end. Wanna see how easy i would be able to throw one into my 31.
Cheers. Luke.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
