Nah he hasn't posted for a while! Wonder if he still has his Line??
Scince he came back from OS havn't heard a thing! Last time i saw him was with you at his house doing your sus swapage! Which reminds me he still has jack stands and some tools of mine and Ash's.........
Duc WHERE ARE YOU???
Woooo Hooooo the best of the rest after Sammy and Duc!
Speaking of Duc....... Where has he gone?? Dropped of the face of the earth by the looks of it!!
Looks like i dribble some shite then, Think that was from a couple of years back!!
you just lucky i don't have an office job i would be posting up big time :P
Whats the go with engineering the emissions in Adelaide rb25/30,custom plenum and power fc. Im about to put 10 Grand in to my r33 motor this year but dont wana go rb25/30 if i cant engeineer anythink.
Iv also been thinking of putting the 10grand into my rb25det(internals only) but still would need to engineer greddy plenum and power fc. Iv also herd that you can have a larger turbo but need to stay in the Emissions range. Iv talk to a few ppl about what im looking at doing but stilll lost so i rang up regency but they said do the work and come down and show us but dont wana wast the money to be told i cant engineer it.
Unfortunately you're pretty much sh1t out of luck.
The way you will want to have it to drive it on the street it WON'T be legal anyway.
Any exhaust you will need to make any kind of power out of the thing won't pass drive by noise regs.
Any aftermarket programmable management is not legal, as it can be adjusted as soon as you leave from the testing.
Spending money on trying to engineer it would better be saved for putting it back to stock if it ever gets defected.
I hate to sound like a wet blanket, but a truly legal modified car is pretty much a pipe dream.
The hole engineering of my car has got me pulling my hair out. The last 2 weeks iv been reading diffrent forums,transport s.a iv talk to the local police and talked to the ppl at regency and none can give me straight answers. Iv just got a hole heap of numbers of engineers in Adelaide that are recognised by transport s.a so im hoping they can give me some straight answers during the week.
With regards to engine changes.
The few vehicle standard blokes I've spoke to have said they can't see a problem with the RB30det as it is essentially just a stroked rb25. Providing no other work is done via camshaft changes etc total power output won't change. Torque will; an increase in torque they don't 'see' as a problem.
Was all very vague but you get that from vehicle standards. :P
Went in a sti wrx stock turbo running 18psi today and shit they fly, but 18psi sounded a bit high for stock turbo tho
Honeypot road didnt seem that long in the sti lol
Mid to low 13sec pass out of a stock car is pretty damn quick. But in saying that the 'old' in comparison r33 gtst with an exhaust, fmic and ecu runs the same times.
Yeah but its something different Dan. :O
Something new/different to play with.
You'll probably get bored eventually and venture back to a gtr though. Couple of nice little mods and 350rwkw.
Then bang there goes third gear. lol
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
