so i can "finish" my cert 3 in cookery...............and become qualified.......only got 2 blocks...a la carte and bufffet both with i have experience in the field............just soooo much
Nope today is the first day, and this weekend wil be interesting for me, I'll be outside of joints alot.........lol
Does this mean i can't even light up in a beer garden at a pub??
you can light up in any 'open air' area. balconies and the like.
its in closed air areas, like the inside of clubs, at bars, etc, that you cant light up or youll cough up a fine.
no pun intended.
Beer Garden are ok.
You may or may not have noticed HEAPS of venues constructing outdoor places where people can drink and smoke in the last few months - well I have anyway.
Beer Garden are ok.
yeah, seems to be the thing to do.
weve built 3 or 4 of them, (one isnt quite finished yet), changed the layout of the first floor to suit, and even changed the reserve time on the machines so people can go have a smoke with relative ease.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
