yeah the bikies do some kind of charity cruise too.
i hate car thieves. which brings me to my question
If cops know that there is a gang doing bad stuff, why dont they have the power to just f*ck them over? why dont they have the power to stop them getting the dole, stop them getting car rego, u know just stop them from being able to do anything at all if they are KNOWN to be involved in a gang that does illegal activities?
that would seriously stop some gangs.
If your talking about gang of 49, some live at richmond not sure on the name of the street but its before knight street. I used to work the street behind them and was good mates with the ppl living right behind them and they used to get cops asking them questions and watching the street all the time. Cops have been doing somthing about it but still it wont end for a long time.
because you then turn into America and end up with more violence then what your trying to prevent heard of 3 strikes and your out still doesn't stop people committing crimes
grabn a r34 Power fc to utilise it all a bit better
going well tho thats for sure
2yrs or so down the track I'll grab some 480cc's and a gt-ss I reckon, but till then will enjoy the Slide unit
lol. Probably because if the cops took all that away they would have more reason to steal. If i was a deadbeat on the dole and it was taken away from me i'd either have to get a job or steal. Now being a deadbeat i'm not going to get a job so i'll just steal more.
The police really can't do that much, it's more of a social issue than anything.
hahaha all good... i just take it thats at the spare wheel then
lol LMAO
nice little miss, nice
Sam, yeah either that (hks gt-rs) or the 2835pros kit one day
hey, who can help me with this?
I can really say I understand it =(
when I get my Pfc I wouldnt mind if someone could help me wire this up.
or should I go to an auto electrician ?
Tangles: That would be very easy to do. Its just a couple of electronics with the +ve feed coming from the ignition (just need to find an ignition +ve) through the components with the diode wired in the right direction, and connected to pin54 and grounded through the resistor.
If you get the parts from Dick Smith or Jaycar, I can help you wire it up if you want on a saturday or sunday :(
cheers, still goobly gook to me tho
lmao
yeah I'll have everything at hand when its ready to go (gotta get the pfc first, and have a date booked for tune)
damn radiator busted itself again.
this year Ive had 1 replacement radiator, replacement water pump (wasnt done at 100,000km service 2yrs ago, although I paid for it), and now the radiator again.
hoping its a hose
any good pressure testers / radiator workers in the city ??
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
