LOL once a poser always a poser hey matty :laugh:
Good to catch up again
for sure mate
and yeah, thats true...........wasnt quite game enough to hit rundle or hindley on the way thru, but squeezed in a bay lap.....
perfect weather to as well, lotsa cars so a bit of stop start. when i got a bit of an opening to giv it a lil bit, it'd built enough fuel up to giv a nice pop (which was rather loud ricochetting off the buildings LOL)
:glare:
Would i be better off getting 17x9 front 17x9.5 rear (need to roll the guards though at the back ?) if i dont want to use spacers ? How would that fit do you know...
The width is one thing BUT offset is another, If Matty has had to use spacers then i would assume you will need to also!!
Matty did have the 9.5's on the rear which sat very similar. I think he changed them to 9s because he wanted to go drifting more often, he got 2 pairs of 9s as another pair of 9.5's weren't available, and he can put slightly skinnier tyres on the 9's (easier to spin up?)
Anyway, im sure he'll anser soon :P
Were spacers used when he had the 9.5's on the back ?
8s on front yeah, not 9s LOL. And thats rite, never ran a spacer on the rear with the 9.5s
9.5s are +18 (gtr offset)
9s are +35 (s13, r32 etc)
currently running a 25mm bolt on at rear, goin to put the 25mm up front tho, and get a 35mm for the rear to push them out more
ran 235s on 9.5s (was a bit hard with 155rwkw to spin 3rd), but now run 215s on 9s (and it spins easy as)
to put 9.5s on the rear of the 31, it required a bit of massaging of the guards
and scandyflick..........that was the plan all along. 2 red 31s.......one mild, one wild.....................
Hmm i really want the car to grip well. So what width would you recommend for mine ? (keep in mind i dont particularly like spacers...but i dont like my rims sitting inside the guards either :P)
how much power u going to be making? thats the question
id probably say try and get hold of some 9.5s for the rear
*edit: my idea just blew thru LOL
Edited by Matty 31
i thought you were getting ben's roh's?
plans always change with him
just spoke to him, he's managed to make them fit on the rear LOL.........and by the sounds of it (20lb hammer) he's got them to fit ............ when the rear coilovers hav no downward adjustment left in them its got to be low LOL
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
