LOL once a poser always a poser hey matty :laugh:
Good to catch up again
for sure mate
and yeah, thats true...........wasnt quite game enough to hit rundle or hindley on the way thru, but squeezed in a bay lap.....
perfect weather to as well, lotsa cars so a bit of stop start. when i got a bit of an opening to giv it a lil bit, it'd built enough fuel up to giv a nice pop (which was rather loud ricochetting off the buildings LOL)
:glare:
Would i be better off getting 17x9 front 17x9.5 rear (need to roll the guards though at the back ?) if i dont want to use spacers ? How would that fit do you know...
The width is one thing BUT offset is another, If Matty has had to use spacers then i would assume you will need to also!!
Matty did have the 9.5's on the rear which sat very similar. I think he changed them to 9s because he wanted to go drifting more often, he got 2 pairs of 9s as another pair of 9.5's weren't available, and he can put slightly skinnier tyres on the 9's (easier to spin up?)
Anyway, im sure he'll anser soon :P
Were spacers used when he had the 9.5's on the back ?
8s on front yeah, not 9s LOL. And thats rite, never ran a spacer on the rear with the 9.5s
9.5s are +18 (gtr offset)
9s are +35 (s13, r32 etc)
currently running a 25mm bolt on at rear, goin to put the 25mm up front tho, and get a 35mm for the rear to push them out more
ran 235s on 9.5s (was a bit hard with 155rwkw to spin 3rd), but now run 215s on 9s (and it spins easy as)
to put 9.5s on the rear of the 31, it required a bit of massaging of the guards
and scandyflick..........that was the plan all along. 2 red 31s.......one mild, one wild.....................
Hmm i really want the car to grip well. So what width would you recommend for mine ? (keep in mind i dont particularly like spacers...but i dont like my rims sitting inside the guards either :P)
how much power u going to be making? thats the question
id probably say try and get hold of some 9.5s for the rear
*edit: my idea just blew thru LOL
Edited by Matty 31
i thought you were getting ben's roh's?
plans always change with him
just spoke to him, he's managed to make them fit on the rear LOL.........and by the sounds of it (20lb hammer) he's got them to fit ............ when the rear coilovers hav no downward adjustment left in them its got to be low LOL
    • Spotted in NYC! Fresh off the boat too it seems!
    • he bridged the 2 pipes together in 2 spots. Making a H pipe. i'll get a photo and post it tomorrow
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
