Screw EBAY... Go to R31 skyline club, a member there, GTS-145 can get them brand new from nissan for $208 I think. (Dont quote me on that)
And dont f**k around with thermo's, Run stock clutch fan and shroud. Works the best.
Edited by R31 drift pig
Hey all
George down at Adelaide Pro Sound FTW!!!!!!
he did my parcel shelf today, has done the best job ever, and cant wait to do my custom boot install hopefully before autosalon.
honestly go see george cause he rocks
one very happy customer :banana:
drove home via blackwood the other night and a guy had dropped his bike on sugar loaf rd. When i got there there were about 4 cars shit all over the road and a guy not looking 100% was a bit of a surprise to come around the corner and see that
it MAY take a little longer to warm up, but if you get a Good kit it'll have a thermostat, so it'll cycle like normal then open up and let oil into the cooler when it hits that temp.
Id do an oil cooler before i did a radiator actaully.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
