How much of a blast are the KETO's ryan!
Even funnier is that my AE71 shits all over my Prepped R31 track car.... Be even better when I finish the sus and put either a 4AGE or SR20DE in it.... and you get the rotor in LOL....
I would just like to say i found out tonight that my stock ke70 would rape my R33 in the hills. Despite Coilovers, fat tread and power. nuff said. most fun ive had all year.
it always end up that way! the old school beats new school! my friends et turbo is crazy through the corners! i followed and every corner i hit at the et speed i seem to understeer and when i don't my tyres feel like they're on the edge of breaking out and my car starts oversteering! while the et just goes through with ease, out in out!
congrats missr34
well my quest for building an r33 gtst on a budget is going nicely! just this week i pulled out a very responsive 185kw atw! i can get to 200 but my standard cat isn't letting the turbo spool anymore\
but here's a pic of the engine! pretty crap quality because it came from my phone
Shit yeah.... I came to the conclusion this morning, that Im going to hold off on work on the 31 for a while, and do some more work to the AE71..... namely rip out the 4K 1300cc and drop in either a 4age or a SR20DE..... just needs a tad more grunt. Going to sort some new sus sometime this week....
Even better is I can drive the 71 on the street.... unlike the 31 :rofl:
gotta hate cars sometimes
fried my starter motor in the drift car this morning...............seems this is why it was being a prick the other week at the dyno day and sounding laboured on start. It wasnt what i thought (with the alternator not charging whilst running) but yeah, attempted to start it this morning. small wisps of acrid smoke from the engine bay..........looked down to the starter motor and it was comin from there. Just ripped it off now and discovered that the RB30 starter motor (mind you, its off a Nissan Patrol) that has been on the car since i owned it has finally packed up
anyone got an RB30 or RB20 starter motor laying around that they dont want (and that works?). I need one sooner rather than later if i can get hold of one. Otherwise i'll hit up a couple of wreckers during the week
Edited by Matty 31
what u guys get for easter?
i got a broken wrist and a bruised ego on the half pipe so the 1 handed drive home i done will prob be my last drive for a lil while :D
and boy did my vocab go out the window and replaced with 1 f word to express my self at the time :D sorry kids but im sure theyve heard those words before
Yours and mine are both KE70's ben, with slant front. The AE71 came out with the 4A-C and not our furious 4k-C's.
whatever.
LOL
All I know is it needs a bit more go, keps finding myself cought out of gear and labouring the f**k out of it. And not a fan of revving to 7000 all the time.
not a fan of 7krpm? you have a 20....no way around it.
:D :D
ill help ya do ya valve clearance tomorrow and she'll be good as gold!!
Edited by Ryanrb25
A Black one tho Cubes??
Very Nice saw my first one up close and personal the other day..even tho its pink was so HAWT!! :D
Guess who's car made the Autosalon 2007 Best of Tour Photo Gallery!!!!!!!!!!!!! :O:bunny::bunny::D
:D
Congrats Mis R34!! :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
