How much of a blast are the KETO's ryan!
Even funnier is that my AE71 shits all over my Prepped R31 track car.... Be even better when I finish the sus and put either a 4AGE or SR20DE in it.... and you get the rotor in LOL....
I would just like to say i found out tonight that my stock ke70 would rape my R33 in the hills. Despite Coilovers, fat tread and power. nuff said. most fun ive had all year.
it always end up that way! the old school beats new school! my friends et turbo is crazy through the corners! i followed and every corner i hit at the et speed i seem to understeer and when i don't my tyres feel like they're on the edge of breaking out and my car starts oversteering! while the et just goes through with ease, out in out!
congrats missr34
well my quest for building an r33 gtst on a budget is going nicely! just this week i pulled out a very responsive 185kw atw! i can get to 200 but my standard cat isn't letting the turbo spool anymore\
but here's a pic of the engine! pretty crap quality because it came from my phone
Shit yeah.... I came to the conclusion this morning, that Im going to hold off on work on the 31 for a while, and do some more work to the AE71..... namely rip out the 4K 1300cc and drop in either a 4age or a SR20DE..... just needs a tad more grunt. Going to sort some new sus sometime this week....
Even better is I can drive the 71 on the street.... unlike the 31 :rofl:
gotta hate cars sometimes
fried my starter motor in the drift car this morning...............seems this is why it was being a prick the other week at the dyno day and sounding laboured on start. It wasnt what i thought (with the alternator not charging whilst running) but yeah, attempted to start it this morning. small wisps of acrid smoke from the engine bay..........looked down to the starter motor and it was comin from there. Just ripped it off now and discovered that the RB30 starter motor (mind you, its off a Nissan Patrol) that has been on the car since i owned it has finally packed up
anyone got an RB30 or RB20 starter motor laying around that they dont want (and that works?). I need one sooner rather than later if i can get hold of one. Otherwise i'll hit up a couple of wreckers during the week
Edited by Matty 31
what u guys get for easter?
i got a broken wrist and a bruised ego on the half pipe so the 1 handed drive home i done will prob be my last drive for a lil while :D
and boy did my vocab go out the window and replaced with 1 f word to express my self at the time :D sorry kids but im sure theyve heard those words before
Yours and mine are both KE70's ben, with slant front. The AE71 came out with the 4A-C and not our furious 4k-C's.
whatever.
LOL
All I know is it needs a bit more go, keps finding myself cought out of gear and labouring the f**k out of it. And not a fan of revving to 7000 all the time.
not a fan of 7krpm? you have a 20....no way around it.
:D :D
ill help ya do ya valve clearance tomorrow and she'll be good as gold!!
Edited by Ryanrb25
A Black one tho Cubes??
Very Nice saw my first one up close and personal the other day..even tho its pink was so HAWT!! :D
Guess who's car made the Autosalon 2007 Best of Tour Photo Gallery!!!!!!!!!!!!! :O:bunny::bunny::D
:D
Congrats Mis R34!! :D
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
