I love cars and I love money, it's just having enough of both that's the problem :)
+ motorbikes :D
Find the right woman to support your 'automotive addiction' and you're set :)
BTW I just hooked up my new Samsung 22" widescreen SyncMaster 2243 monitor for the PC ;) Time to watch some movies :)
I have 22" LCD screens at work and hate this small 17" at home ... so I went out and bought an LCD better than the one I have in my office. :)
Edited by RubyRS4
hahaha nice ruby was you 17" lcd and what you doing with it i know my dad wouldn't mind another one
No the 17" here at home is the standard non-lcd monitor, aka boat anchor.
This setup isn't finished yet. I've upgraded my vid card to support two LCD screens in unison. Going Swordfish style ;) Got this setup at work, and I like it so much I'm bringing it home. I'll prob do alot of drafting at home too as well as work, so I need a good setup.
thought i'd throw this over to the wasteland.
From [sA Cars Spotted Thread #3]
man that car is wack....BN kits DO NOT suit R33's It is the ultimate way of ruining a nice looking car. ;)
I personally wouldnt touch those kits at all, agreed; they are pretty 'meh'.
But i dunno, there is just something about that particular car that captures my interest and makes me look twice!
When you look at an example like this though:
so i did something stupid and signed myself up to this zoo mag comp thing for the real car search, so seing as though an fto is currently winning i figure im gonna need some help from people with slightly better taste, although mine aint that great its better than a damn fto lol. So if people are feeling kind and generous, swing a vote my way and try and help me turn my boonger drifter into something nice lol.
http://realcars.zooweekly.com.au/ViewProfi...x?profileID=469
Well it came up saying thankyou for your vote, so i assume i voted for u!!
I also remember hearing a shout out for you on Fresh sometime over the weekend.....lol
You know its fruitless ... it'll be a Hummer that wins ;)
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
