i may have gone crazy but im sure we used to be able to edit all of our posts, now it seems i can only change the last 1 i made.
this means im accountable for all i say :) i cant handle that kind of responsibility you know how much crap i talk and how often i offend people and need to change my statements to appear like im a decent human being to anyone that hasnt read them yet :(
is that how it is for everyone now?
was just gonna change my cruise thread to done with pics
Edited by gzilla
ha, ha, too late Dan, you're stuffed now..........just go and swallow a bottle of sleeping pills :)
hahahaha all the more reason to donate once you donate you can even delete your own posts if you think they were that silly :P
>>How to Donate<<
this means im accountable for all i say :down: i cant handle that kind of responsibility you know how much crap i talk and how often i offend people and need to change my statements to appear like im a decent human being to anyone that hasnt read them yet :D
nah, we start at 6am, however we haven't got much on at the moment and with a little bit of persuasion we convinced our boss we weren't needed today. :D
And even then it wasnt much pursuasion LOL..... You heard if we're working tomorrow?
f**k I was bored today.
GET ME A JOB THERE :down:
im so over my boss was meant to do overtime today then he cancels on me because i forgot to put an ingredient in a batch then had to put it in and re-blend then colour didn't come out quiet right, AND then the guy that's been there 15 years couldn't figure out what to put in to fix it and i had to do most the guess work :D
tell me that's worth $16 an hour
hahahaha all the more reason to donate once you donate you can even delete your own posts if you think they were that silly :down:
>>How to Donate<<
Thanks Madaz, was wondering how to donate. I was going to ask... Honest... Considering skylinesaustralia has given me so much, i thought i might give alittle back :D
were u home this arvo?
the keto wasnt there (puddle of oil was tho LOL) but i still knocked on the door..........mandy seemed to kno i was there tho :(
the keto wasnt there (puddle of oil was tho LOL) but i still knocked on the door..........mandy seemed to kno i was there tho :)
What time was this? Picked Dom up from work @ 3, then did some shopping, was home by 4 ish I think.
Dave is right though, should have called me LOL. Ill only not pick it up if I dont want to talk to you :):D
Puddle of oil is from the stupid 4K inverted oil filter dumping it's guts like it had a hot curry LOL. Did an oil change yesterday. Ill grab some H/D Degreaser... no - one will ever know. :(
GET ME A JOB THERE :blush:
im so over my boss was meant to do overtime today then he cancels on me because i forgot to put an ingredient in a batch then had to put it in and re-blend then colour didn't come out quiet right, AND then the guy that's been there 15 years couldn't figure out what to put in to fix it and i had to do most the guess work :whistling:
You only get 16 dollars an hour????? thats crazy.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
