was wondering if anyone on here knows how much power a pair or Garrett Gt2860r's would be able to make on a RB26. as someone on SAU is getting them imported brand new for $2,150 delivered a pair.
oh no way!
FTW
Haha awesome pic Ben! Is that the Lower NE/Sudholz (however you spell it) intersection?
Yeah
I was taking the GTR out that day to go to Birdwood Motor Museum for a work function.... (and I was sadly disappointed, so much Holden propaganda, grr). I was on 60 the entire frigging time except for that time I went into the inside lane to avoid some slow bastard in a caravan. So yeah. I got reamed that day.
*simmers*
-D
Edited by Dohmar
Crappy isn't it?
yeah pretty lame, considering I got another one 6 months ago, 121 in a "100" zone (of course it was the part where the 100-110 transition happens). Not happy jan. Seriously considering buying a VDO speed alert so I don't get retarded.
-D
Keep in mind you will need bigger fuel pump, injectors, AFM's and an ECU to take advantage of it all, I don't know your current setup
all i need is injectors and fuel pump, the other parts have allready been takin care of. :banana:
That's what I'm going for Chad, f**king awesome price and power to boot! Seen reports of power between 350-370awkw! :banana:
Definitely will make that power.
Here's mine with Garrett Gt2860r's, upgraded fuel, PFC & zorst......stock internals, stock cams, stock manifolds.
With a really crappy tune:
just put up for sale my 18" mantis and vl walkinshaw bar off my wagon so i cant invest in a pair of those turbos!! thanks to DSTROY for the motiveation to return ma vl back into a sleeper
spotters fee if anyone finds a buyer
:D
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
