was wondering if anyone on here knows how much power a pair or Garrett Gt2860r's would be able to make on a RB26. as someone on SAU is getting them imported brand new for $2,150 delivered a pair.
oh no way!
FTW
Haha awesome pic Ben! Is that the Lower NE/Sudholz (however you spell it) intersection?
Yeah
I was taking the GTR out that day to go to Birdwood Motor Museum for a work function.... (and I was sadly disappointed, so much Holden propaganda, grr). I was on 60 the entire frigging time except for that time I went into the inside lane to avoid some slow bastard in a caravan. So yeah. I got reamed that day.
*simmers*
-D
Edited by Dohmar
Crappy isn't it?
yeah pretty lame, considering I got another one 6 months ago, 121 in a "100" zone (of course it was the part where the 100-110 transition happens). Not happy jan. Seriously considering buying a VDO speed alert so I don't get retarded.
-D
Keep in mind you will need bigger fuel pump, injectors, AFM's and an ECU to take advantage of it all, I don't know your current setup
all i need is injectors and fuel pump, the other parts have allready been takin care of. :banana:
That's what I'm going for Chad, f**king awesome price and power to boot! Seen reports of power between 350-370awkw! :banana:
Definitely will make that power.
Here's mine with Garrett Gt2860r's, upgraded fuel, PFC & zorst......stock internals, stock cams, stock manifolds.
With a really crappy tune:
just put up for sale my 18" mantis and vl walkinshaw bar off my wagon so i cant invest in a pair of those turbos!! thanks to DSTROY for the motiveation to return ma vl back into a sleeper
spotters fee if anyone finds a buyer
:D
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
