bah. as if my partner wins something at Kadina Show and Shine and i dont hahahaha.
well done tho on winning Best 4 Cylinder with the WRX, Lex im proud of ya for winning your first trophy. :ninja:
just remember i have 10. YOU have 1.
:blink:
well just got my car back from jeff...
pulled 189.9rwkw on 14psi....
afm meter was maxing out?????? green label?
ok i have a gtr power fc modded for gtst.. now jeff thinks coz the gtr runs 2 afm this may be the reason mine is maxing out?? would this be the case?
coz i thought i would hit atleast 200 with my setup?
also my clutch is sooooooo hard to drive with! stalled it 8 times on way home!!
oh i wanna cry!
The RB26 AFM's are rated less than the 25's I know that for certain, this is probably your issue... question though, is you AFM an RB26 one or 25? If you are using a modded 26 PFC with a 25AFM you shouldn't be having any problems
EDIT: Just saw you have a 32, no idea where the RB20 AFM's fall in the scheme of things, would think the 26 has a greater reading range however
Edited by heslo
STEVE!!! its not funny! im about to throw something!
thats wat i thought! well im gonna ditch my pfc and get a remap! i think the PFC is holding me back??? joel i know u wanna help hahaha
oh spewing so bad! and my clutch made it worse hahaha
damn wed!
jeff said he thinks the green label is having trouble working with the gtr pfc due to a rb26 running two afm! he said i should get a z32 and i agree but im just trying to c y i would be maxing out at 190???
isnt that strange??
and yes i will toughen up hahaha its wat happens when u have a slipping clutch for 6months and get used to being able to ride it hahah
isnt that strange??
I would assume the green one is a RB20 AFM??
I can understand why the 26 PFC would need 2 AFM readings as its twin turbs, but i dont see any reason why they cant wire it up to 1 AFM and have the same reading for both on the PFC, Im no mechanic or auto elec........
hahaha i lol'ed
give it 2 days of driving with new clutch and you wont look back
GTR afms are brown but i think there pretty much the same as the green ones just different wiring
go here for a nights worth of READING
of Luke of you do think of getting the R34 MFD this will be handy for you >>HERE<<
here is a AFM chart too :merli:>>Here<<
:blink: In other words... toughen up princess, right Steve? :ninja:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
