hey guys after a bit of help. my car is missing under boost when on more than 9 psi. i tihnk eithermy fuel pump needs an upgrade or my sparkplugs are fouled..... got half the day off tafe tomorrow so gonna check the sparkplugs first.... check their quality and age. just wondering where would be a good place to get spark plugs and at a good price?? ive also heard more expensive isnt always better for rb's? as they dont last aslong?? also how do sparkplugs usually last kms wise??
many thanks for your help in advance... not putting up a thread about it cos there is no point.
Also check your cooler pipes......
Irridium plugs are around the $120 mark!!
getting there sbout 45 mins on it tonight
alot of time is wasted looking @ tuts reading then trying then undo'ing when it fails re-reading redoing re-undoing you may notice i chopped up another picture and overlayed it in there and thats where the red on the rear shot has come from
Mark - also check the gap alot of plugs are sold @ 1.1mm and should be .7-.8 for high boost
at 1.1mm they may run ok but up the boost and run crap
no, 120 the set, Simon32 says just get copper there fine you just may need to replace them sooner
iridiums are meant to last longer thats why there dearer oh and there made of iridium i guess
i heard irridium dont last long? and 120 each... yowza!
thanks steve yeah ill gap them and check them out. got hks sparkplugs in the vl.. might just swap depending on condition
Reuben your Air box is that basically what the R33 one looks like ?
I believe so! I've got a HKS pod under it. Its only there to appear stock ... so is the rest of the work to the bay. Got to keep it looking stock as a bone :)
I'm also replacing my plugs and ensuring the gap is 0.8mm.
Mmmmm ... coilpacks :D
Ahhhh i thought that was what you were up to!!!
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
