thanks for the input guys. and thanks guy i might take you up on that. ill call you if need be.
thanks for your input cubes!
comp has 4 gig ram, core 2 extreme(quad core), 768 3d card(overkill) and most games i can crank up.. a few stall but with grid it glitches and freezes up like crazy. running 1920x1200 res... hoping xp will fix this issue and just not happy with vista on the whole.
I have alot of mates who use vista and haven't heard of the issue's your describing i would almost put it down to being a dell
just because they claimed it was the fastest ns whatever if they used inferior parts for memory or graphics card your going to end up with alot of problems
i also know nvidia aren't that great with there drivers so it may be a case of searching if other people are experienceing the same problems with dell systems or the same graphics drivers
just as an example with the game grid i was having corrupted gfx on the demo so i rolled my drivers back and was all good now i have the full version and even newer driver haven't seen that problem since
*cough* Nvidia drivers are probably the most solid drivers out there on the market. If you're using beta/alpha drivers then you're bound to have issues, but historically Nvidia have had much better drivers than ATI. That said, I've owned ATI and Nvidia and both have had isolated incidents with driver releases from time to time...
-D
3d card is nvidia 768 x 16 8800 ultra. how would i update drivers?
will try that before i whipe it.
www.nvidia.com
go to download drivers
enter 8800 ultra as the gfx type. download the release that suits your operating system (vista)
Once downloaded, Run it. Voila, new driver installed.
-D
hmmm moving house sucks.
me and the missus are putting our unit up for rent, after spending mega bucks on a re-furb.
it went into the paper on sat, and the net >click here<
we have 3 couples coming through it tonight for an inspection!
one couple has offered more then the weekly rent, they want it so bad!
but the real estate agend doesnt like the look of them lol.
its all good though saving more money FTW
moving back with missus mum FTL
having a double garage all to myself FTW
real estate agent fees, FTL
I'm in the talks at the moment with the bank ... looking at bidding on a massive 4 bedroom home (with 2 double garages) on a huge block of land :(
If I get that house, I'm def throwing a house warming party!!!!!
*fingers crossed*
Well for what its worth my specs..
All using the latest drivers from the respective websites.
Gigabyte EP35-DS3
Gigabyte 8600GT @ 1680x1050
All rock solid memtest (test 5 and 8 for 24hrs) and prime stable.
Runs Grid fine no hang ups or stutters.
I had a slight issue when I was running a 400fsb where it was rock solid in prime and memtest yet BF2 would still randomly drop to the desktop. Dropped it back to 333 with the same overclok and its now fine.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
