Bought another Skyline Today!
An Auto RED S3 Silhouette R31
New head on the rb30, goes very well, stock LSD still works very well, Interior is immaculate, paint is a little worse for wear tho..but i dont care. Will make a great tow car/daily.
Edited by Ryanrb25
Sweet what did you pay for it??
Whats the Auto like in it? Still sweet?
Can you come and tow me I have blown the clutch in my car!!!
I wont tell you what kind of car I did it in, I am to embarrased!!!
LOL
Edited by OzCarImports
Hahaha thats awesome Shaun
Rhys you can roughly expect 170-180rwkw at boostworx
(this figure is based on another guy here that made that power no mods)
you guys are welcome for the group buys and building relations with traders, when you get an alarm Rhys foot forget to mention sau for your discount
as for painting stuff i saw our other recommended alarm installer and he gave me the card to a guy up the road from him i will give him a call and see how he pulls up on price
sweet, i was just tryna get a estimate cause my brothers now got around that at the wheels of his s3 rx7 and im yet to line him up haha need that tax back already so i can start having a play with the power side :(
sorry if this sounds stupid, but whats the max voltage on an S2 rb25det AFM?
ryan was saying that the random cut outs, could be due to AFM maxing out on me......
when i give it a hard strap, the FC hand controller reads ''5015''....
it didnt cut out on me at the time though..
next time it cuts out, ill have to rember to check it.
Congrats on the purchase, looks very tidy !
Im still stuck with modifying mine lol. Any tips as to where i can get Nissan and Ford wiring diagrams anyone ????
The S2 afm is the same as the S1 afm and r32 rb20det afm with regards to voltage vs airflow; only difference is the plug.
Mine hit 5.1v at around 180-185rwkw.
You shouldn't be experiencing a fuel cut with the pfc.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
