Happy Birthday Carl
Damo you want side feed injectors
Damo has a 34 so he will need top feed high impedence injectors i think. Cant remeber whether they are high or low impedence injectors needed.
Well it depends on how much power your after
there is a calculator that you can put in how much power you want to make and it will tell you what size injectors you will need, it will also tell you what power different inj. Will make
So would i be aiming for 550cc or thereabouts for my setup?
440's are good for ~260rwkw and can be squeezed to around 290-300rwkw with some additional fuel pressure.
550's are usually good for a 'little' over 300rwkw before they require more fuel.
If it were myself... Go a set of large sard twin spray 800's they atomise fuel well and then you have the option to tune on E85 and pull an additional 30rwkw out of it and pay less for fuel. :D
Damo i bought mine from Deatschwerks (spelling) in America great pricing and they have a pretty good rep on here.
I have 550cc yuo can buy them off me if you want for the price i paid for them as i think i might go larger.
Bolt straight in with no issues and they have been flow matched from there factory in the US.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
