Happy Birthday Carl
Damo you want side feed injectors
Damo has a 34 so he will need top feed high impedence injectors i think. Cant remeber whether they are high or low impedence injectors needed.
Well it depends on how much power your after
there is a calculator that you can put in how much power you want to make and it will tell you what size injectors you will need, it will also tell you what power different inj. Will make
So would i be aiming for 550cc or thereabouts for my setup?
440's are good for ~260rwkw and can be squeezed to around 290-300rwkw with some additional fuel pressure.
550's are usually good for a 'little' over 300rwkw before they require more fuel.
If it were myself... Go a set of large sard twin spray 800's they atomise fuel well and then you have the option to tune on E85 and pull an additional 30rwkw out of it and pay less for fuel. :D
Damo i bought mine from Deatschwerks (spelling) in America great pricing and they have a pretty good rep on here.
I have 550cc yuo can buy them off me if you want for the price i paid for them as i think i might go larger.
Bolt straight in with no issues and they have been flow matched from there factory in the US.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
