hows this hyundai wanted $234.34 for an injector for a 2000 hyundai accent, stanvac auto wreckers will give me one for $30 lol. :thumbsup: now i just have to put it in haha.
I paid $330 for a genuine GTR injector from Japan! I needed 6! Ended up costing me like $2200...
I could have bought a Hyundai Excel for that haha
totally.... u can get sard 800cc's for $900 or something on the GB section... crikey
-D
Haha yeah I know, my mechanic told me that he could get a full set for that + a tune! But I need a ECU which isn't on the cards at the moment.
But it really is the going price for the genuine injectors. I rang up Nissan, and they told me $360 each. Apparently the GTR injectors are becoming more sought-after now due to the fact that most of the older model GTR's injectors are begining to leak.
But, 6 new injectors later, the GTR's running alot better and no more fuel smell!
Crickey you can get sard 800's for a little over 600 your all getting ripped off
and go see a new mechanic because someone like Jeff from the speed lab could of remaped your standard ecu and you still had change for a beer from $900
hahaha google street photo taken when my car is not home :thumbsup: though i did want to see it
Yeah I checked my house first and there wasn't any cars home, so I did the following:
lol k i checked my house my old work and my new work and my mates house and its not there ether...haha im checking the x's house now lol,seriously tho where the hell was i on this day!
:ermm:
Yeah, lobethal was done around the time we had that heat wave, and some parts of Nairne were done at a later/earlier time in the year, as it's all cloudy and shit in the pics (the loby pics are fkn sunny as, with dead grass every where :P)
Sard injectos and an ecu remap for $1000 you say? Not bad. Think its the actual injector leaking, not because of the o ring... Can actually see fuel running out :S not much, but enough.
That's exactly the issue I had. Shaun was saying how alot of the 32 GTR's are doing this now with the stock injectors. I had 2 leaking, though and the others were on their way to that point.
You get a bad fuel smell, too. Everywhere I took it, people would say "you've been giving this one a flogging!! I can smell the fuel still!" haha
(virtual)drive down the main street of barker, just after the bike shop its sunny, then move ahead one spot and its dark, wet and cloudy. haha.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
