damo, get a hand controller, its definetly worth it, alot of people have had their car tuned then gone to drive it on the road only to realise they have a higher than safe knock level because the tuner didn't take into account the dyno is only a tuning tool and not the same as driving on the road. Plus you can keep an eye on boost levels aswell and chicks dig it.
i accidentally posted this in the cars spotted thread lol, my bad....
im doing all my oil swaps this week, anyone with a 32 gtr got any advice???
so far i got
engine: motul turbolight 4100 10-40 or 5-40
diffs: Castrol SAF-XA
gearbox: castrol syntrans 75w-85 or syntrax 75w-90
and the transfer case, attessa & powersteer can use the same: castrol Transmax Z
advice????? also oil filter advice? this my first swap on a modern car, used to simple escorts
i have heard (and this may be bollocks) that this is a yakuza run firm.... and you will be lucky to get the car at all..
there are some jzx100's and 90's that make me happy in the pants on this site :banana:
this one makes me wet
so far i got
this is just some ruff notes i've got saved on my PC from a few years ago, nfi about if the prices are right etc, but it might help you figure out what you need
Engine: Motul 300V Power Racing 5w-30 $95/4lt, $38/2lt, $450/25lt
Manual Trans: Motul Gear 300 $24
Diff: 75-140???
PowerSteering: Dexron III: $9
HICAS: Dexron III $9
Brakes Motul RBF600 $30
Spark plugs: PFR6A / PFR5A (NGK platinum) - gapped to 1.1mm or 0.8mm if you are missing
Coolant: Nulon 9lt 50%
Transfer case oil: Nissan Matic D 1.8lt
Frount Diff oil: GL-5 85W-90 1.0lt 75-140???
Rear Diff Oil: LSD GL-5 80W-90 1.5lt 75-140???
Brake Fluid: RBF600
Clutch: RBF600
Power Steering Fluid: Nissan Power Steer fluid 1lt
Engine Oil: factory spec 7.5W-30/ 5W-30 4.6 litres
HICAS: Nissan Power Steer fluid 2lt
ATTESA: Nissan Power Steer fluid 2lt
Manual Trans: 75W-90 GL4. 4.1 litres - Redline lightweight Shockproof Gearbox Oil?
yeah +1.
Also important to note the ramp rate the tuner is using......Shoot Out Mode (200) is a waste of time for the street, should be 150 or it will definitely run in different areas of the map (detonation city) on the bitumen and up hills.
just had Ryan n the guys at AUSSIE DYNO N TUNE tune my car today had a few issues with wheelspin but after putting ryan in the boot gave it a few runs and pulled a constant 300rwkw then on the last run pulled 327.4rwkw on only 19psi with only 18 knock level!!!!!
great guys down there fully reccomend them 2 any1!!
great talking 2 u Ryan top bloke, ill be back there with sum softer tyres n maybe biggr injectors so we can screw sum more boost in2 it maybe.....
http://myspacetv.com/index.cfm?fuseaction=...ideoid=41815405
Edited by ovrtym33
Top effort.
What are the specs? Turbo exhaust manifold? etc :thumbsup:
The rb25 pfc can display a boost reading if you hook up a cheap map sensor.
Paulr33 has the info on in his PowerFC Faq on how to get it working.
Top effort.
CP PISTONS
EAGLE RODS
1.2 HKS HEAD GASKET
GREDDY EXHAUST CAM GGEAR
256' 264' HKS CAMS
TURBOSMART EXTERNAL WASTEGATE
X FORCE HIGH MOUNT EXHAUST MANIFIOLD
GARRETT GT 30/40 .82
POWER FC
555 NISMO INJETERS
TOMEI FUEL REG
CROWER VALVE SPRINGS
ETC..................
oooooo i might just do that, i have a feeling it's a "friends" friend coz she sent me a msg
saying she was getting threating calls aswel.
might get him to check out another number aswel, had 3missed calls from it then sent a msg
asking who it was and haven't got anything back from the number lol
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
