lol im no guru but im more than happy to help. Ill find out what map sensor is suitable for the readout, im pretty sure the n13 pulsar map sensor was used on someone's pfc i seen a while back...maybe cubes knows a bit more than me. Be more than happy to help you guys hook it all up.
cheers mate!
mate, dont let a pos like that give you a first glimpse of a 33...not a chance in hell will it impress you...non turbo auto with 180thou on the clock.... go find a decent manual s2 gts-t to test drive.. much different. Oh, i can't believe they want 12 grand for that haha.
Sure, if I drive in first gear all the way :)
I've gotta learn manual :(
i'll let you with my imobiliser on :(
i see though! you haven't popped your skyline cherry! because you wouldn't be saying that if you did
I sure haven't.
Im a skyline virgin. :)
How embarrassing :down:
lol.
I sure haven't.
Im a skyline virgin. :wub:
How embarrassing :(
lol.
you can drive my car on three conditions
1) has to be a massive wide open space with nothing to hit and no other cars
2) i sit there with 2 hands on the hand brake
3) can only use 5th gear
:P
:P
gonn suck for the first 180-ish kmph, but after that it's all good times =P
Fishy, they are standard GTR calipers as far as I can tell
so your saying he has small hands?? :wub:
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
