Npz Luke and Yes Craig may even be $190
GUYS that go and See or Ring Ric DONT DONT DONT forget to tell him Steve sent you otherwise no discount
he has made up %15 loyalty cards which he will give me the next time i go in and i can hand some out but STILL need to say STEVE sent you
:banana:
You drive a Skyline, plates or no plates, you're still in the shit
Fecking LOL, truer words were never spoken :P
Also Nardi > all. I had one of those wanky bullshit Isotta wheels on my 180 and it was homo as to drive with. Nardi + 30mm bosskit spacer = win (or just get a Deep Corn for like $150 more :P)
nardi = win
i want to get one for the drift car, so much better than the Personal wheel i got on there at the moment
yays for RDO...............might start calculating the size of enclosure i can build for my subs in the patrol............. i know i need 26 litres per sub for a sealed enclosure, just gotta do some maths to work out how much i need to take out for the wheel tub lol
the threads were being monitored by their "legal representative". so even with warnings to people to keep their mouths shut, well we could see that working as well as the "dont post in here unless completely necessary". No one listens. Email sled [email protected] Adrian [email protected] or me [email protected] / [email protected]
Well I woke up this morning feeling much, much better ... flu all gone :banana:
Still groggy and overslept, but f**k it! Got things to catch up on. Still got the day off work. :P
just wondering if anyone knew much about greddy t517z x2 suit gtr. power potential, posatives and negatives
cheers in advance
I have seen these on a gtr with 700cc injectors re build and usual mods on 1.24 bar boost run 454rwkws... they are great turbo's plus they bolt into the stock location. i was planning on running these but im thinking of swithching to the GT2871R from CGU.. great responce not much difference from stock... hope that helps out a little i got a mag article with the write up on those turbos if ya wanna have a squizz
Rann really is a f**king idiot. :banana:
too f**kin right!
I wonder if they'll get heavy handed with all bikie association and whether that also includes the Longriders who are ex outlaws.
I have a couple of mates that are members, does that mean that I can no longer catch up with them once a month??
yeh there is no clear line drawn in the sand, i think you will see the law fall through in a few months, when they try to arrest or fine there first victim cause i can see way too many loop holes apearing
too f**kin right!
at the end of the day you are correct, there's no clear definition of what a bikie or an outlaw is. So if Roo or I have a sordid past, does that mean you're all in trouble if you come to Villis tonight?? Or will I be fined or arrested if I drop into their clubrooms once a month............ridiculous, they are EX outlaws so I'd like to see some defined legislation 1st.
are they laggy Mike?
did ya mean the CGU ones i plan on getting or the trust t517z?? cause the trust ones i haven't seen the dyno sheet but they're not to far off the N1's (supposedly.) and The CGU ones are basicaly the same as N1's but way better...
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
