the trust ones that jenkies is interested in. If they are similar to the N1 , id say they are fairly responsive, similar to a stock turbo, but build alot stronger so they can handle more boost.
i tried the search function but got nuthin :banana:
so ima ask it here, whats the widest wheel you can get on a 32 gtr? and the ofset you need to acheive this?? guessing around the 10-11 mark?? would be for a 18 inch wheel aswell
10inch wide with a +18 offset....
just wondering if anyone knew much about greddy t517z x2 suit gtr. power potential, posatives and negatives
cheers in advance
hey mark, where ya been bud?
I'm no expert on these snails but I think you may find they have journal style bearings as opposed to the Garrett style ball bearing
carl, what did you use for your glovebox setup? (materials)
its a piece of black plastic that is about 4mm thick that has been cut as a facade, and have put a couple gauges in there... used to have ebc inthere too, but i choose to abide the law nao :laugh:
i'll prolly be at villis if u wanna see it, im planning on re-doing it soon
I've been doing a fair bit of research on new snails...
t517z x2: Beware theres 2 types of housings, an 8cm and 10cm one. 8cm is equivilent to GT5860-7(HKS GTSS), 10's = GT5680-5(HKS GTRS) and SLED is correct that they aren't Ball Bearing. From what I've heard quite linear quite peaky compared to the Garrets.
The -5 is bigger than the -7 if that makes any sense.
Some specs here: Gtr twin turbo comparisons
I've settled for a set of 34N1's because they're supposed to be similar to stock response.
so that would be bout a 275ish???
i got 275s on mine dont ask me what rim size n offset though dont know. tires start getting pretty expensive at that size by the way :)
ur welcome to have a look when i get it going again.
Edited by Inline 6
my neighbours are sooooooo annoying, there over here all the time.
1 of them (Samantha i think) was talking to my mum yesterday and said she thinks she knows
me, so my mum and dad hounded me to go talk to her (i didn't), she left eventually.
yeah i'm not a very social person when it comes to neighbours haha, i know no1 on
my street and i'd like to keep it that way :)
HELP please!! Just after ideas atm on what it could be but when i take my foot of the accelerator i get a clunking noise sounding like its coming from either my dif! Its now also sounding like the back end is almost bouncing while driving. How do i check to see what it is and advice please??? :)
