lol is that all? its pointless explaining how wide you can go if you dont understand offset. google "offset", read up, then youll understand what we are on about.
wtf? please explain HOW it is pointless? i understand offset but that has no bearing on my question, i simply asked what was the widest rim you can throw on a gtr without it rubbing, and obviously you would state the offset for that size.....i can do without the smartass-ness :P
Edited by rhys5169
well, finally going to bed after pulling the wiring out of my bike frame for the past 6hrs
don't be too noisy during breakfast you guys so I can sleep in
you get home in one go?... you didnt seem to have any trouble on south rd
got my spacers on this morning @ wheelworx....
looks tuuuufffff!
but rubbing on the front guards even though they where rolled!
so wont be lowering it any more, i hot +25mm all round, so i should have settled for 20s on the fronts
but oh well, still looks sweeeet :P
question ,
my car has way too much power for an N/A , it revs past 7000rpm without a problem .
what would be the first thing to check to see if its got stock parts in the engine ?
cause there is no way it has 140kw~
lol yeah :P it was pretty much the first time i said it out loud... and it dawned on me
was good catchin up last night mate.. the celly sounds awesome btw
haha, love it when shit like that happens :P
cheers dude, still sorta think its a bit noisy, but i love the noise it makes jsut the same.
lol, yeah it rubs major on the fronts, rears are ok........
think i gotta go back for smaller and sell off the +25s
im not too keen on the look of the fronts now either....i need other ppls opinions :P
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
