SLED: i just filled up with mobile 8000, i like so far, dropped my idle slightly, engine doesn't sound as harsh, seems to drop the revs smoother when i put the clutch in, and just gives what seems like a quiter, yet deeper idle/cursing noise
i think i'll give it a few more tanks, see what economy is like.... BAHAHAHHAHAHA... but thumbs up so far!!! :D
and s2 of californication FTMFW!!!!! how good is it so far?!?!?!?!?!
"no one should ever have to see their own O face"
"did you just touch my ass?" LOL!!!!
Edit: removed partial spoiler
Edited by Fishpaste~
FINALLY ITS BACK ,
was so happy when i saw it was out
btw , did you used to work at adrenalin ?
i would consider switching to Mobil 8000 but in Mobil's wisdom they closed about half of there station's and there's no Mobil's (maybe one) on the way to Melbourne and very few over there didn't see any really
I mix between Mobil 8000 (mostly), Shell Vpower, and BP Ultimate
get down to 15litres left and put 50 in of the next fuel on the list
:D
man these knees are crazy
just wanna hang & thats a teribble way to think
love my kiddies and being stay at home dad to youngest (eldest is yr-R at school), & the little bunny rabbit is becoming a nice companion (follows me a bit, cute)
just so sore, killing me slowly inside & out
start SR morphine patches tomorrow
on the good side, the Stagea looks pretty nice with the $110ea 17x7.5 +38 BJR Graphic mags. lowered another 2 circlips front and rear to 360/345mm
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
