SLED: i just filled up with mobile 8000, i like so far, dropped my idle slightly, engine doesn't sound as harsh, seems to drop the revs smoother when i put the clutch in, and just gives what seems like a quiter, yet deeper idle/cursing noise
i think i'll give it a few more tanks, see what economy is like.... BAHAHAHHAHAHA... but thumbs up so far!!! :D
and s2 of californication FTMFW!!!!! how good is it so far?!?!?!?!?!
"no one should ever have to see their own O face"
"did you just touch my ass?" LOL!!!!
Edit: removed partial spoiler
Edited by Fishpaste~
FINALLY ITS BACK ,
was so happy when i saw it was out
btw , did you used to work at adrenalin ?
i would consider switching to Mobil 8000 but in Mobil's wisdom they closed about half of there station's and there's no Mobil's (maybe one) on the way to Melbourne and very few over there didn't see any really
I mix between Mobil 8000 (mostly), Shell Vpower, and BP Ultimate
get down to 15litres left and put 50 in of the next fuel on the list
:D
man these knees are crazy
just wanna hang & thats a teribble way to think
love my kiddies and being stay at home dad to youngest (eldest is yr-R at school), & the little bunny rabbit is becoming a nice companion (follows me a bit, cute)
just so sore, killing me slowly inside & out
start SR morphine patches tomorrow
on the good side, the Stagea looks pretty nice with the $110ea 17x7.5 +38 BJR Graphic mags. lowered another 2 circlips front and rear to 360/345mm
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
