Looks like the Group Buy thread for all the Garrett turbos is now closed.
Hope no one here was still waiting on any turbos.
Yeah i emailed the guy a couple of days ago about a price without the group but cause i needs to get new turbos.
mmm indian. harvest of india on o'connell st best by far. me and the ex got the craving for indian food cronic and tried nearly everywhere in adelaide.
Indian temptations on Main Nth road is little more than a kitchen and a couple chairs, but theyve always got native clientelle. And they make really good stuff.... thats where I usually go...
Before then it was Padmas rasoi for their vindaloos, or The Spice Kitchen for their butter chickens.... Harvest of India I haven't tried but I hear they have tindaloo on the menu which is worth a lookie I suppose. Beyond India are all round good too but their food is a little more australian-ised.
-D
i love the vindaloos, if u go to harvest of india, try the beef with cheese naan bread. beyond india up the rd is ok. it would be like the cafe primo of indian resturants. family-ised. but they make some hot vindaloos. hotter, the better. theres a alright place on rundle st too, down the end near the corner of the parklands.
Edited by steveP
is it that hard to find shit now a days that people have to ask for directions to there local off a car forum :(
>>Google is your friend<<
Just f**king chill out aye
Actually no, google is not my friend. Tried looking up 31 Hindmarsh Square on google street veiw? You get the opposite side of the f**king square to where 31 actually is. Great help if I'm trying to find a place for the first time :rofl:
Thanks Dohmar for the info.
I've got a pair of -5's that I may be selling..........they would only have done about 2 or 3 tanks of petrol.......so should be like new still.
$2000 pair
$2000 pair
I will be in touch i dont have the coin at the minute anyway... im either getting a set of those of the -7s but please kep me posted SLED... :P
Mmmmm, indian :P
Anyhow ... I got myself a jar of chilli sauce at the Show. I call it "atomic meltdown" :) Rated 10+/10.
Tried some on a cracker and WOW :( I love spicy/hot foods, and this sauce was def hotter than anything I've had yet.
My mate use to run a pizza shop and he'd make hot pizzas. Even put chillis in the pizza base, just to see me sweat. ;)
When I have the house warming party at my place, I'll be inviting people to try it :P
If you dont mind me asking, why the sale??
I will be in touch i dont have the coin at the minute anyway... im either getting a set of those of the -7s but please kep me posted SLED... :)
I'm toying with a different idea at the moment.........the -5's are definitely the way to go for the best balance of power vs response......ask Martin Donon.
I'm prepared to hold them with a decent deposit Mike.............or anyone else.
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
