It just didn't squeel cos I'm awesome Craig :(
Seriously though that stuff helps, and also chamferring the sides of the pad with a file. Do both and follow proper bed in instructions and you have no worries
Well that depends on how cheap you want to sell it for :D
i wouldnt thats the thing. its mcf**ked. even though id sell it as that, i wouldnt want to do that
Aww your selling it!! :D But you just got the Car trailer!! :(
im re-shelling jess...........this chassis is buggered. Put 4 axle stands under her and the chassis only sits on 3
plus im stepping it up a bit. While i hav the chance, its getting cage, seam welding, coils, better wheels, and a bit more power (in the form of a TD06)
just want to mention, if your organising an sau event, please put one post in the SAU Calendar thread in the stickies:
put the date, and the title, then the link underneath, eg:
"27/10/2008: Tupperware Party
www.skylinesaustralia.com/forums/omgimorganisingatupperwarepartybro.html"
how the hell do i make my Non Available power skyline sound decent and don't say turbo because ive already been through that tonight
its hard to explain the shit noise it makes , just sounds shit .
idles nice , soon as you touch the accelerator , BAM ! shit sound kicks in
Solution for NA noise making goodness.
Individual throttle bodies with velocity stacks infront of them and nothing else
Ridiculously large cams
Proper tuned length extractors and a well sized exhaust
lightest flywheel you can get
= snappy as fuck, crisp, angry sounding NA, that will still get raped by mildly worked turbos, but sound about a million times better doing it.
In all seriousness, I wouldn't bother hey :)
new exhaust dude, simple.
yer i know but i have nfi wtf to get :(
dont put a homo cheap ass cannon on it, 2.5 cat back system with a good quality rear muffler with tip/s of your choice.... should have you car sounding nothing like auto non turbo supra boat in no time :)
cheap cannon is what the previous owner put in it , welded it on to the stock system iirc , so yeah sounds like cock
i can get a jun bl muffler for like $120 second hand , how much you reckon it would be to put a new system on my car ?
just frustrated at the crappy sound my $2 tin can is making
i know that sound youre talking about Mitch, heard it on many other N/A skylines. ultimate poo.
a proper 2.5'' system with extractors, and resinator should have it sounding much better
yeah it actually pisses me off , tempted to get a stock system cause i hate it so much
yer i know but i have nfi wtf to get :)
aussie dyno and tune Port Rd hindmarsh, Say your off SAU. Cheapest in town.
fisher performance did my n/a 31.. and it sounds very good.. advanced headers, 2.5" exhaust, hi flow cat, turbo mufler, and a resonator for $1000..
def happy with that.... the best part is it doesnt drone at 60, 80, or100kph
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
