No probs!
yeah its good, thanks again.
even better: 2nd december, Boostwerks is doing ALL the stagea head work and retune, service and attessa servo/o-ring repair. very reasonable quote too.
very reasonable I reckon, considering theres porting etc to be done (Im supplying almost everything, bar cam gear seals and one gasket)
will be around 230awkw Id say, with tonnes of torque
shite, 18k car plus 18k mods
lol
:P
im just about to get on a plane 2 go overseas WOOT WOOT
heading to Bangkok then Chang Mae then Vietnam then Phukett then back 2 Bangkok
see every1 in a months time.........
Adrian ya car better bloody better be finished by then!!!!
Have a good one Dan,
Adrian's car is done, just gotta get tailshaft back now.
thanks Ryan
see u when i get back, then we'll put those breaks on then my car will be "FINALLY FINISHED" and no more to spend on it...............i hope
SLEEPER
lmao dave i just read ya post in the sau users thread..hahaha i pissed my self wildly lol
and im going to say it again...my car has never been the same since u molestered it hahaha
hmm, this is a different question. im 21 now and mum is pretty sure im not covered under the family health insurance now. Does anyone have their own health insurance, and who are you through?
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
