Well, sorry to the folks who went to work today, but we and I took the 3Litre Streeter for a belt down to Victor Harbor. WOW what a ride! By far the fastest car I have ever been in (and not surprisingly, given his OS Giken block alone is worth more than my car - they are $30k fyi).
Some pics are below. Enjoy.
edit: decided to remove the movie.
hehe yeah mate - it is a hard slog - but some of us have to do it.
However, if you were following earlier a couple of pages ago, I finished typing my valuation reports from yesterdays jobs at just after 5am this morning. Yes, that means I did nearly 10 hours of property inspections during the day, then typed up reports for about 6+ hours more last night.
I think I was entitled to take today off ;)
Mmmmm lunch and a beer at The Crown was bloody awesome today too :(
just found out my great grandma died this evening..
so ill be booking some time off tomorrow, so i can attend the funeral in millicent.
Sorry to hear Craig.
If she lived in Millicent she was probably a relly of my wife or at least they knew her.
Again, condolences.
hi Guy, did u manage to pick up your exhaust from morpowa ok???
i have a bottle of Jimbeam 1.25 litre 4 u i pikd up from the duty free store 4 ya
Hi Dan
The exhaust is still on your car (which is in the back shed)
They will call me when they take it off.
Enjoying the holiday? My bet is that the beam wont make it home, I know if I bought it it wouldnt. LOL
Hi Dan
oh damn sorry bout that Guy
holiday is pretty good so far, fly out 2 vietnam 2moz morn
haha i bort 2 bottles of it in melbourne 1 4me n 1 4u and left yours at the duty free store 2 be picked up on the way home, so it's pretty safe
that's the one that was sitting at wilall a month or so ago! and isn't the osgiken 3litre insane? i know of a dude who has keir's old engine in his track prep r32 with 2 trust t51's i think, it pulled about 420kw? with over 1000nm of torque and i remember when he took me for a spin! started off in 2nd and ripped up the semi slicks like they're nothing and man can this guy can drive as well
one of my friends just picked up a vr4 4g63 motor, gearbox and a full aftermarket turbo set up with ex-gate, manifold etc for stuff all
he only wants the gear box for his car.
doesnt anyone know of any rwd cars that we can get CHEAP and dump the motor into or does it have to be fwd or awd to work?
Edited by Import S13
haha yeah ive been in a few cordia's with vr4 motors and they were bad enough but were wanting to put it in something to slide :P
but i figured that would be abit hard to put this motor into something that is rwd :D
maybe we should make a rally basher hmmm
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
