Errr Brendan - you do realise it is a GTR with around 450rwkw and has run low 10's? You would have kept within sight range for around 30 seconds, and would have been it :D
umm yer, you reckon I couldnt keep up in the twisties, being an ex-bike rider whos used to lines and 220+kmph corners?
lol, as said, $50 is a bet id take :laugh:
all in good fun
Im bored too... i hate exam time. One down today (animal health) got three to go.. sigh. I have business management for applied science saturday morning.. yes thats right an exam on SATURDAY MORNING! Adelaide uni is so mean :laugh: Can't wait until it's all over!!
Sez
Edited by Ryan&Sez
Im bored too... i hate exam time. One down today (animal health) got three to go.. sigh. I have business management for applied science saturday morning.. yes thats right an exam on SATURDAY MORNING! Adelaide uni is so mean :) Can't wait until it's all over!!
Sez
Far out thats just tired me out reading all that and i don't have to do any of them!!!
my other exams are animan nutrition and animal behaviour, welfare and ethics - that's the one that puts you to sleep!! I'm so glad that this is my last full time semester :)
Sez
Edited by Ryan&Sez
I can't believe it either.........I doubt if the block alone is worth $30K........maybe with very expensive internals ie. a short motor
Errr Brendan - you do realise it is a GTR with around 450rwkw and has run low 10's? You would have kept within sight range for around 30 seconds, and would have been it :)
You had better believe it mate .... BLOCK only. Definitely nothing else included. The crank that Munro is using was a cool $5k on top, then pistons and all the crazy gear incl. 1,600cc injectors - yes you read right. This is how he has spent $180,000 on the car. And yes, he has receipts.
Ring Keir Wilson right now and ask him - he has bought around 5 of the OS blocks all up due to blowing motors etc .... his wallet knows EXACTLY how much they cost .... I am not sure what exchange rate they were purchased at, but I am sure it was better than it is now too .... only recently he pointed out to me one sitting under his work bench at Willalls looking all lonely - I told him I would happily give it a home :) .... but as it isn't quite in my price range there it stayed :)
i found this 1,627,500.00 JPY (Japan Yen) = 26,404.34 AUD (Australia Dollars)
>>source>>
RB30 OS-E2996
Developed for those special customers who feel that 2.6 liters is just not enough.
OS Giken RB30kit contents
RB30 OS-E2996
- 1 cyclinder block
- 1 billet crankshaft
- 6 billet-forged connecting rods
- 7 crankshaft main bearings
- 6 connecting rod bearings
- 6 forged aluminum pistons
- 1.3mm metal gasket (1.2mm, 1.4mm and 1.5mm
gaskets available)
- 1 timiing belt
- 1 belt tensioner kit
- 14 custom made reinforced crank cap stud bolts and
nuts
- 3 M6 bolts
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
