how much for the n1's? my car needs a chrissy present
If your interested in a cheap pair of N1's mine will be coming off over christmas cause im upgrading to Garretts... only thing the seals need replacing on em as oil is getting on my manifold... so if your interested jus send us a pm if not i'll jus post em up in the for sale section.
yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeehhhhhhhhhhhhhhhhhhhhhhhhhhhhhaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaawwwwwwwwwwwwwwwwwwwwwwwww
Just got my 34 back from the workshop. Took it there to replace the water pump, and not only does my car now stay icy cool (old pump was corroded and cavitating badly), but the rattle from my engine bay is GONE! A few of you would have heard the rattly beast on the cruise last week or at bowling a while back - and it is NOT top end issues - it was just the damn water pump. So, no rebuild for me after all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I am heading down to Vili's to get my calendar at about 7:30pm - will catch up with some of you there
PM sent
well don't nick off straight away, hang around for a bit & I'll try to get down there to
If there not firing its multimeter time to see if the problem is with the loom or the injector.
i can hear clicking on all of them i think.. i just hope there not f**ked otherwise its gonna get expensive!!!!
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
