hey jarrad, got my grommets from supercheap on sth rd (near finders med centre). they have heaps of difffernt sizes..
im not a fan of any spoilers,exept lip ones, i like subtle stuff. spesh on 32's, the ass end looks so much better without. makes for a heaps tougher stance IMO
