Interesting read:
http://www.ascc.gov.au/NR/rdonlyres/097A66...eport_jacks.pdf
Regarding deaths while working on the car when the jacks fails. Example from one of the death incident: guy jacked up his land rover and put SPRINGS under the range rover to support it up and removed the jack so the range rover was only held up by springs while he was working on it... guess what happens next.
OMG ... one nit-wit had the car on ramps, in gear only, and removed the tailshaft ... guess what happened next :P
Some people just shouldn't go near cars.
Told ya I had a big back yard.
Pic from a while ago. You can see where the pool is going in. Got Council approval and the SA Water permit! :)
The tap for the garden hose is where the house extension finishes, and still got 200m2 open space :P
ooooooo 28-135
how have you found it as just an every day lens ?
is the picture quality superior to the standard 18-55 kit lens ?
It's an Ultrasonic Lens with an Image Stabilizer..........it kills the 18-55 lens!
A great intermediate lens.
LOL thats not a big back yard, (my dam is bigger than that)
this is mine
a comfy 100 achres (lots of room for a private trst track and drag strip if it wasnt so hilly (no flat quarter mile strip :( )
Hmm, 8.5km from the CBD? :)
Altough I would kill for a large block for some dirt biking ... I love being so close to the city.
Edited by RubyRS4
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
