Interesting read:
http://www.ascc.gov.au/NR/rdonlyres/097A66...eport_jacks.pdf
Regarding deaths while working on the car when the jacks fails. Example from one of the death incident: guy jacked up his land rover and put SPRINGS under the range rover to support it up and removed the jack so the range rover was only held up by springs while he was working on it... guess what happens next.
OMG ... one nit-wit had the car on ramps, in gear only, and removed the tailshaft ... guess what happened next :P
Some people just shouldn't go near cars.
Told ya I had a big back yard.
Pic from a while ago. You can see where the pool is going in. Got Council approval and the SA Water permit! :)
The tap for the garden hose is where the house extension finishes, and still got 200m2 open space :P
ooooooo 28-135
how have you found it as just an every day lens ?
is the picture quality superior to the standard 18-55 kit lens ?
It's an Ultrasonic Lens with an Image Stabilizer..........it kills the 18-55 lens!
A great intermediate lens.
LOL thats not a big back yard, (my dam is bigger than that)
this is mine
a comfy 100 achres (lots of room for a private trst track and drag strip if it wasnt so hilly (no flat quarter mile strip :( )
Hmm, 8.5km from the CBD? :)
Altough I would kill for a large block for some dirt biking ... I love being so close to the city.
Edited by RubyRS4
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
